73dodgeman
just seeing who is runing an old skool style 671 needing to pick some ones brain, tnx
There are several members running one. What do you need to know?
One bit of advise though, don't just take one persons opinion on them. Ask around and talk to as many people as you can, there is a lot of info and ideas that may work for some but not others. And don't assume the the supplies you get from the blower companies are correct, BDS gave me a junk intake and it took a while for me to figure it out and then I had to fight with them to replace it, also some of the hardware had to be replaced before I could start it.
for the price of there smallblock manifolds they should realy back there product up to the max when you complained they should have sent a guy to you to have a look at it,with that crazy pricing...
I had a problem with a surge at idle, up and down real bad, had to lower the fuel pressure and it smoothed right out, just a thought.
