I recall reading about this before. Radiators painted black, NASCAR engines, other instances as well.
What do you people think?
I'm not convinced of or doubting this theory. I just am looking for some rational explanation.Isn't anything black if it's under a closed hood not exposed to light?
As an old physicist I recall that black is the best at dissipating (radiating) infrared which is what the engine produces (see Black Body radiation). The best absorber is also the best radiator.
It may be true, but the difference would be minimal. Convection is going to remove far more waste heat than radiant losses, by orders of magnitude.
Radiant heat losses increase as a function of temperature differential, and so significant heat shedding won't take place until we'll beyond the operating limits of many engine designs. That's why every engine I can think of employs convective cooling via water or forced air.
It's also worth noting that radiant heat exchange would require any heat shed from the engine to be absorbed by an adjacent or nearby material, typically in direct line of sight. The heat then would need to be pulled from that panel or part in order to continue absorbing heat from the engine..
In other words: a proper mix of coolant will do more for you than a black can of krylon.
You thinking of going all Chebby and painting your engine bay black?I recall reading about this before. Radiators painted black, NASCAR engines, other instances as well.
Heck no!You thinking of going all Chebby and painting your engine bay black?
Also, sitting in the sun, my buddy's dark blue Ram was always hotter inside than my white Ram.
There is one thing I can tell ya. Very hard to find an oil leak on a shiney black engine.
Not being a wise azz but dark skinned people are from hot climates (africa, middle east). Not because of the sun but skin pigment. Natures/GODs way of keeping a body cooler through heat dissipation?? Food for thought.
There are some people do that.You thinking of going all Chebby and painting your engine bay black?
I'm pretty sure that's different. The melanin blocks UV light, which causes injuries. It also blocks the light needed to synthesize vitamin D, and with much less light in the higher latitudes in winter and consequently less vitamin D deficiency, prior to mechanized travel and vitamins people DIED or became more susceptible to disease because of vitamin D deficiency. Evolutionary pressures killed those with more inherent resistance to skin damage from sunlight, as well as selecting for REDHEADS!
So, Merry Christmas!
