Anybody in to early Dakota's
Mopar General Discussions
  1. 68383GTS
    68383GTS Well-Known Member
    7,403
    884
    Nov 15, 2007
    East Peoria,IL
    Local Time:
    4:06 PM
    I have a 88 Dakota Mopar Express V6 5 speed 4x4. Can I get rid of the transfer case and front axle and shafts and bolt on 2 wheel drive A arms and brake spindles? I want to convert it to a 318 LA rear wheel drive only. Or do I need to find a 2 wheel drive frame? My frame is solid.
  2. Syleng1
    Syleng1 Karma is real and Life is short... FABO Gold Member
    1,874
    1451
    Jul 5, 2005
    North Franklin, CT
    Local Time:
    5:06 PM
    Get the correct frame.
    find a good 2wd truck and save a lot of time and sell your 4wd. Those frames were known for rust. I’ve Replaced my dads 96 4wd frame twice now. Rotted bad just under the back of the cab. Getting hard to find good frames. Only 80k on his truck too. Old man truck. He loves it. Never even sees winter. Sad design.
    • Agree Agree x 1
    • moparmat2000
      moparmat2000 FABO Gold Member FABO Gold Member
      17,136
      6117
      May 13, 2010
      Grand Tetons
      Local Time:
      4:06 PM
      Come on down to Abilene Texas. We have a huge junkyard named FM600 wrecking. Lots of trucks , all are rust free. People junk them with lots of miles because they are worn out and have no rot.
      • Like Like x 2
      • Syleng1
        1,874
        1451
        Jul 5, 2005
        North Franklin, CT
        Local Time:
        5:06 PM
        That’s funny- up here in the North East- we have what’s left of rotted vehicles with not a lot of mileage.
        • Thanks! Thanks! x 1
        • Agree Agree x 1
        • 68383GTS
          7,403
          884
          Nov 15, 2007
          East Peoria,IL
          Local Time:
          4:06 PM
          I was thinking if frame rot bad and mine is solid just convert it.,if possible.Short bed frames are harder to find.
        • moparmat2000
          17,136
          6117
          May 13, 2010
          Grand Tetons
          Local Time:
          4:06 PM
          Not uncommon to see 400K on the odometers, perfect body and shot drivetrain.
          • 68383GTS
            7,403
            884
            Nov 15, 2007
            East Peoria,IL
            Local Time:
            4:06 PM
            Are the 4x4 5 speed tranny's and transfer case electronic at all? I thought of bolting in my 318 LA to the 5 speed and transfer case.I am sure a 88 Dakota has some kind of computer so I am not sure what to do there. Other than eliminating the computer. I could always use a painless harness to replace the wiring
          • RustyRatRod
            RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
            64,725
            37693
            Jun 7, 2010
            Georgia
            Local Time:
            5:06 PM
            I'd be into them if I had one. I love the early square body Dakotas. They are miniature versions of the 82 to 93 Ram trucks.
          • 68383GTS
            7,403
            884
            Nov 15, 2007
            East Peoria,IL
            Local Time:
            4:06 PM
            They are starting to get a little hard to find...the short beds anyway
          • RustyRatRod
            64,725
            37693
            Jun 7, 2010
            Georgia
            Local Time:
            5:06 PM
            I just searched Macon Craiglist and there are ZERO first gen Dakotas.
          • moparmat2000
            17,136
            6117
            May 13, 2010
            Grand Tetons
            Local Time:
            4:06 PM
            All over the junkyards out here in west Texas. Rust free too
          • dodgedifferent2
            dodgedifferent2 Well-Known Member
            2,586
            377
            Aug 8, 2008
            southwestern, Ontario
            Local Time:
            4:06 PM
            I was planning a big block 96 reg cab sb dakota.
            Then I realized that I should just pull the sb stroker from dart and put into dakota. Then build a monster 512 bb for the dart.
            Covid hit and everything has slowed to a drip. Not even a trickle.
          • RammerJammer75
            RammerJammer75 Well-Known Member
            521
            662
            Aug 28, 2020
            Kingsport, TN
            Local Time:
            5:06 PM
            I know people think they're ugly, but I really like the '97+ design. I do like the older trucks as well, but I've owned several (still have one) 2nd generation Dakotas. How many people remember the D50/Mighty Max?
          • Bill Crowell
            Bill Crowell FABO Gold Member FABO Gold Member
            945
            489
            Oct 16, 2007
            Diamond Springs, CA
            Local Time:
            2:06 PM
            As the former owner of an '87 Dakota V6, you've gotta keep a really good and properly-adjusted choke thermostat and choke pull-off diaphragm on those engines in order to have them start and run properly when cold.
          • rustycowll69
            rustycowll69 Well-Known Member
            2,273
            1060
            Feb 19, 2016
            Pacific northwest
            Local Time:
            2:06 PM
            I've got an 89 Shelby Dakota, 230k miles, runs like a top. 0 to 50mph it's really quick. Shelby must have been paid for every time his name was used on it. Must be a couple hundred "Shelby" all over it.
            He practically disowned it afterwards. Can't get any of the Shelby specific parts from them.
          • toolmanmike
            toolmanmike FABO MODERATOR Staff Member FABO Gold Member
            53,047
            38553
            Jan 18, 2006
            Iowa
            Local Time:
            4:06 PM
            Here's my 2. The white 2 wheeler had a bad spot on the frame. I found a solid chunk at a local yard and had the local welding shop weld it in.
            • Like Like x 1
            • RustyRatRod
              64,725
              37693
              Jun 7, 2010
              Georgia
              Local Time:
              5:06 PM
              Hell yeah! That's dedication! Down here, we'da just chunked that bad boy and got another whole truck. LOL Well, "I" wouldn't have, but 90% of folks would. lol
            • sireland67
              sireland67 FABO Gold Member FABO Gold Member
              9,301
              3501
              Oct 27, 2010
              WV
              Local Time:
              5:06 PM
              I have a couple dakotas, good trucks.
              This is a pic of a friend of mine (Rip) big block dakota, his dad still takes it to shows. Its a nice truck.
              • Like Like x 3
              • RammerJammer75
                521
                662
                Aug 28, 2020
                Kingsport, TN
                Local Time:
                5:06 PM
                Is that a glass hood? It's a good looking truck for sure.
              • sireland67
                9,301
                3501
                Oct 27, 2010
                WV
                Local Time:
                5:06 PM
                I pretty sure it is.
              • 93ragtop
                93ragtop Well-Known Member
                181
                98
                Dec 23, 2015
                Va
                Local Time:
                5:06 PM
                Hey, I have a 87 V6 4wd 5spd. I am converting to a 5.9 magnum.....
                Here is a list of things that I know are different, 4wd vs 2wd.
                1. Rack and pinion used on 2wd vs ball on 4wd.
                2. Coil springs on 2wd vs torsion bars on 4wd.
                3. Motor mounts are totally different. 4wd is bolted to the front diff.
                4. Body mounts are different, at least polys are only listed for rwd......
                5. The axle is mounted below the springs on 4wd and above on 2wd.
                All that aside, on another forum I frequent, there is a 96 2wd that was converted to 4wd, but he used a SAS on the front.
                Good luck and I look forward to hearing more!!
              • Krooser
                Krooser Reform School Graduate
                2,723
                2211
                Jul 19, 2015
                Central Wisconsin
                Local Time:
                4:06 PM
                I was in South Dakota last week...
              • Syleng1
                1,874
                1451
                Jul 5, 2005
                North Franklin, CT
                Local Time:
                5:06 PM
                I know she’s a 2000 model... but can I still hang with the cool kids? V8, 4wd, auto she’s a fun little truck. Sometimes I just get tired of driving my full sized diesel Dodges and she is just the ticket! image.jpg
                • Like Like x 1
                • barbee6043
                  barbee6043 barbee 6043 FABO Gold Member
                  12,885
                  5483
                  Jul 20, 2008
                  Shepherd, Texas ( SE Tx)
                  Local Time:
                  4:06 PM
                  They told me back 50 years ago, buy mechanical parts up North and bodies down South!!!!!! Or back when I was in good ole Missouri, buy it all right there, because parts and bodies are cheap!!!!!!! Ks also!!!!!
                  Just don't buy any that spent winters in KC or St Louis!!!!!!!
