I built my AR. Stag lower, CMT flat-top upper, LMT BCG with KNS Perma-Pin, RRA LPK, KNS anti-rotation/anti-walk pins, RRA six-position CAR stock, RRA charging handle with PRI Big Latch, Bushmaster 14.5" M4-profile 1:9 barrel with 1.5" Izzy comp, CMT carry handle, MI front sight, YHM Specter gas block, JP FFT. Great little rifle...Nothing all that special, but built from solid parts.
I assembled the rifle at home, including the upper...Which wasn't as difficult as everyone made it out to be.
Yes, the front sight is on backwards. That has since been remedied. I've also added a Magpul MIAD since that pic was taken, which I much prefer to the grip that came with the RRA LPK. After a few thousand rounds I noticed that one of the pins would crawl out one side of the lower and bind up the works, so I installed the KNS anti-walk/anti-rotation pins. I really should take better pics of my guns.
My best "accessory" has been good mags. I've got a pile of the older Colt twenty-rounders and a few PMAGs...Both have functioned flawlessly. Your best bet is to shoot...A lot. Buy a bunch of ammo and maybe think about reloading.
I'm contemplating putting together a 300 BLK empty upper/barrel/handguard for the rifle...I can just swap BCGs into whichever upper I want to use and re-use mags as well.
