Get ur builder to grind the crank for a Chevy rod, then get 1 set appropriately .100 thou longer. Or buy new pistons. Kim
View attachment 1715323409 View attachment 1715323410
Can’t find the order form, but they a custom JE pistons only number on them is 315F, think that is the raw forging number.
These are the pistons you had .020 out of the deck?View attachment 1715323409 View attachment 1715323410
Thanks Kim looking into new pistons now, keeping the 516 heads and adding 1.74 exhaust valves.Get ur builder to grind the crank for a Chevy rod, then get 1 set appropriately .100 thou longer. Or buy new pistons. Kim
Still working on sourcing near zero deck pistons, so far n/a. Keith Black tech support has been good, but we just don't know why the pistons are so low in the hole. Machine shop has no answers, other than using dome piston, which I don't want for many reasons.....I'd like flat tops within .012 TBDJust all the way around. I much prefer a closed chamber head....and you already have them. I would put big valves in the 516s, and get a zero deck height piston for that 383. Hardened seats on a street car are really not necessary, especially as light as the A bodies are.
Thanks, still trying to find close to zero deck pistons. Something not right with this at .105 below the deck...Don't forget a .020 head gasket either.
Thanks, that's what I was talking with KB tech center today, (mine is 60 over). The block is already decked is what was confusing me .... Going to ask the machine shop to measure and give me the deck height.Here is what you want. Keith Black KB Performance Pistons KB162-030
You have to mill the block to end up with zero deck height. With the above part number you will need to mill about .0265 off the deck to get zero deck height. Most machine shops will deck a block for around 150 bucks. It's highly recommended anyway with a Chrysler block because their deck tolerances were terrible and they are almost always out of spec.
I would go zero deck. If you want the piston in the hole, you can just subtract that amount from the total I posted above.
Mine has a casting date of 1/31/67What years did Chrysler produce the raised block 383?
Maybe you have one of them.
If your interested in building power above 3600rpm BB. Open chamber way to go. Dont ask me how I know. Proper cam unless compression is unworthy closed is economical.
Street cars Thought were talkin heads vs/ compression/ economic build.So, closed chamber engines won't make power above 3600? Somebody better tell a LOT of former Stock Eliminator record holders.
All around streetcar IMO 3.91 gear BB 2" headers 1000cfm Open chamber ported heads all I need to beat anyones *** on the road. At least so far...forget the nitrous.
Your combo would suck the life out of a 383 on the street. you won't be beating much on the street with this combo in a 383.All around streetcar IMO 3.91 gear BB 2" headers 1000cfm Open chamber ported heads all I need to beat anyones *** on the road. At least so far...forget the nitrous.
Again, this is not a cross country set up...lol But a town to town exitementYour combo would suck the life out of a 383 on the street. you won't be beating much on the street with this combo in a 383.
I've gone from closed to open chamber heads three times.. She's no race car, just want a 9.5/1 street car, I can enjoy and sell it....If your interested in building power above 3600rpm BB. Open chamber way to go. Dont ask me how I know. Proper cam unless compression is unworthy closed is economical.
