1967DartGT
I was wondering if anybody is running a Comp Cams 260H in a 273? I'm asking becasue I have a new one I picked up for 50 clams but have also been considering buying a XE256H or XE262H instead. Will I notice any real word difference in performance and/or gas mileage if I use one of the dual pattern grinds, or do you think I should stick with the 260H? This will be a daily driver but I want more oomph than with a stock grind. I'm running 2.76 gears for now, but that could change. I will also be using 302 heads with a little work to them, ~9:1 compression, small tube headers, dual exhaust, 500 cfm carter carb. Intake is yet to be determined.
Cheers,
Kevin
Cheers,
Kevin
