dibbons
How is it performing?
Detonation on 11:1? Someone doesn't know how to build an engine.Water injection works very well....when done properly. It was used as far back as WW2, possibly before then.
Systems like the Snow system use a high pressure pump that aerates the water into a mist & it sure as hell works. Friend had this system on his 11:1 engine & it stopped the detonation. Snow uses 2 or more nozzles that go into the intake, with nozzles available in different sizes. The old Holley system is just a single nozzle in the air cleaner.
Wouldn't light throttle pinging be Air fuel ratio or timing?It had light throttle pinging,
I had it in Vixen and it was a vacuum leak.Wouldn't light throttle pinging be Air fuel ratio or timing?
