Just something, I have never seen. If you went W-2's,of course you made other changes. Was it worth, the effort. Still feel a W2 design, is worth it. Post responses here,I like all feedback.....
Never done it.But I have heard its a whole new world when it comes to valve train,Kevin.
Thank You,this is kind of meat post's ,I am looking for. Thank's for ,the post...!Y
Depends what you want from the combo. Street car or race only? Probably does not really make sense to do it unless you utilize those heads to their full potential. You're not going to see a huge gain over ported heads until you start getting into porting and higher lift cams etc. Whatever combo you come up with is likely gonna make peak power at a higher rpm. What they are is a better starting point. Ported W2s will get you well beyond a ported factory head.
Besides the valve gear, you need specific W2 intake and headers.
I have W2s on my car but I got it with them already installed. It's a milder street combo - MP .557" solid cam, Victor 340 intake, Harland Sharp rockers, TTi 1 7/8 step headers, approx. 3,500 stall, 4.10 gear. Had 4.30s originally. Goes to 7,000 rpm. Probably makes around 400-425 hp. Best time was 11.97 before I got it. Made a lot of changes but mostly chassis. No times after changes yet. Should be faster.
If I do build a different engine for this car at some point I'll probably go with the RHS heads I have or some Edelbrocks and get them done up.
Reading the last few responses confirms that my particular combo leaves a little bit to be desired. I often feel like the car should have been faster than 12.0 in the 1/4. It was mainly run in the 1/8 mi. so it may have been running out of breath with the 4.30s. It's a basic, no frills Duster though, couldn't have weighed much over 3,300. Really should have been mid-11s at least. QUOTE]
I was wondering the same thing why your combo wasn't fastener than that. It sounds like a real healthy setup that should be in the mid to low 11's I would think. I will say you'd probably benefit from a 950HP or something over the 750. I run a 950HP that around town and it performs really well.
To the OP, I have worked W2's and they do make some great power. I have no comparisons or dyno sheets to go off of though. But like others have stated, you need to port them to really wake them up and get the full potential. Old design but it's a good one.
Again, I think it may have had a little too much gear. When I bought it, I talked with the previous owner at length about it. He ran the car at Irwindale in CA which was the 1/8, hence the 4.30 gear. I told him I was planning to put in a 4.10 gear I had and he thought it would be a good choice. He didn't think it would affect E.T. much if at all, it's only a 5% change. Might even MPH a little better? It's got a 28" tire and a low gear set in the trans. He shifted it at 6,800 and went through the traps at 7,000.
He also said it might benefit from a bigger carb but I have no plans for that at the moment. I am staying with the engine and drive train as-is for now.
I would think 4.10's and 28" tire would be perfect (because that's my combo too! haha). Is it spinning a lot? I plan for my car to be in the 10's and I am using a setup similar to yours. 11:1 motor, ported W2's, .645 lift 266/277 dur @ .050 roller cam, 1.5 Harland Sharps, Victor W2, TTi 1-7/8, 8" 5500 stall Dynamic converter with 727, 950HP, triangulated 4 link, 325/50/15 rear tires, etc. If he was going through 1/4 traps at 7000, that sounds about right to me.
I run 4.56 gears with 28 inch tires and a low first gear and it does not seem like to much gear with my W2 headed 408 SB, but my car weights over 3400 lbs with me in it.
I shift at 6800 and go through the lights at 7000.
My car has run the best of 11.06 at over 121MPHs in FULL STREET TRIM, full exhaust hooked up, spare tire in the trunk, heater, stereo, 91 octane fuel and street tires.
I have put over 9500 miles on the motor so far plus around 65 1/4 passes so far this is with a small solid roller cam.
Car has gone 11.11 with a 3.73 gear that I run in the car most of the time.
Car was @ 7,000 with the 4.30 gears. Theoretically the 4.10 is less than ideal with a 28" tire.
Even though the components are similar, your cam is way bigger and you have more compression than I do. Plus, your converter is looser than mine.
I don't know. I think I'm gonna have to disagree on that one. The 4.10 with 28" tire is really the perfect in between combo for street driving and still getting decent times at the track. It's essentially the same ratio as a 26" tire with 3.73 gears.
Yes true. I was just trying to make a point that I think your car has much more potential than what it is showing. It just sounds like it needs a couple little tweaks and you'll be mid 11's no problem and maybe even low 11's.
How much work was done to the W2's port wise and what size valves?
Good knowledge. A buddy (runs a speed shop,knows Mopars), sold a roller cammed /11.7 actual comp 340 to a customer. The customer supplied a set of Manning /Brady ported standard castings ,2.02/1.60 X castings. With a 4000 stall converter,and 4:56's out back(27-28" slicks,),ra an 11.60 at 117. The customer wanted ported Edelbrocks, the shop owner quote" not worth the money, in the difference." I watched the heads get slightly over 300( this was Y2K era),on a reputable flow bench. All he picked up ,was a tenth. Trap speed, the same. Swapped a tunnel on,more can,all the tricks. He moved to Florida,car ran the same there. Needed seasonal maintenance (likes N20),picks up mildly W-2's .(Picked up,four tenths, with all the same but pistons/heads/valve train....). All on pump gas.Yeah, that's probably true. However, based on calculations I did with regard to tire size, gears and rpm, 4.30 was right on. If it were a race-only car, I probably would have stuck with the 4.30s. This is all on paper though and the 4.10 is in regardless of the math.
I actually built the 4.10 several years prior to getting the Duster. It's one of the aluminum center sections that Mopar was selling about 10 years back. I basically just wanted to put it in for no other reason than I got tired of looking at it on the shelf. I figured it would not make a huge difference and might even help. There is/was a lot of torque multiplication going on in the driveline with the low gear set in the trans and the 4.30 gears. Probably takes a little horsepower to get it going.
Agreed. :thumbup:
Most of the stuff I did to it over the last year was weight reduction and chassis. I gotta figure what was done (a lot - see here) should be worth a couple tenths, engine and trans being the only things that remained basically the same. Tuning and driving are the last hurdles.
And again, I'm just playing devil's advocate in regards to whether W2s are worth it. They are probably the best of the SBM iron heads so if you think about it that regard, they are worth switching to regardless of financial commitment.
