Anyone ever rigged up a 2 step switch to run off your brake pedal?
If you use the two step off off your brake light switch. The rpm will be the same and the brake pedal travel will be the same if you stage it t
at the same brake pressure.
Yes, I've considered triggering the 2 step off the brake light switch. Seems to me it would be a lot easier to just put a 2 step button on the steering wheel. I don't know how consistent I could be with brake pedal travel.
Yes, I've considered triggering the 2 step off the brake light switch. Seems to me it would be a lot easier to just put a 2 step button on the steering wheel. I don't know how consistent I could be with brake pedal travel./.;/.,./?.,;/'
Doing that way, it does not come off the switch fast enough, you need to be able to just wiggle your foot and it releases it
I used to use an old Ford Falcon Brake light switch
that was pressure activated. I got it from Auto Zone.
It worked well but not adjustable. You would need a bypass
switch.
