Anyone need parts? 62 Lancer 6 cylinder push-button automatic sitting at U-Wrench-It in Omaha
ron hug
Active Member
omaha
If it has the engine, you should look to see of it is an aluminum block 225. It could be.
You can tell if it's the 170 easy. If the water pump bypass hose is real short.......like 1" long it's the 170. If it'a like 4" long it's the 225.......or a swapped in 198.
Valve cover suggests a '70-up engine swapped in, so probably a 225 or possibly a 198. Heater delete car! Someone ought to grab that heater delete plate just to keep one alive as a reference; that's a seldom-seen part.
"9-12-19" scrawled on the LH quarter panel suggests there might not be very many days before this car is crushed and shredded, speaking from experience.
Cool! Did you get the heater button blockoff plate from the instrument panel, too (if the instrument panel was still present)?
You should get them bumpers too. They ain't makin anymore of um.
