RyanUpdike70
what kind of shocks u running
I'M USING A .020 360 WITH KB107 PISTONS SET AT ZERO DECK. STOCK 340 RODS, STOCK 360 CRANK. ITS BALANCED EXTERNALLY WITH A FLEX PLATE & DAMPNER. HUGES SOLID CAM & SPRINGS. OUT OF THE BOX ELDELBROCK HEADS (NO PORT WORK), HOLLEY STRIP DOMINATOR INTAKE & 750 D/P CARB.
1 3/4 HOOKER HEADERS, & A MSD6AL IGNITION.
TRANSMISSION IS A 904 WITH A 2:74 LOW GEAR, MAN VALVE BODY, & 9 1/2 DYNAMIC CONVERTOR.
8 3/4 WITH 3:91 GEARS.
BEST ET WITH THIS COMBO, 11.57 @ 115MPH, 60FT 1.62
I CHANGED THE GEARS TO A 4:30 & CHANGED THE CONVERTOR TO AN 8 IN.
BEST ET WITH THIS COMBO, 11.28 @ 117.5, 60FT 1.48
E/T streets are sticky DOT approved street slicks basically and hook like mad but as others mentioned they fade fast and are very sticky, but don't get caught in the rain unless you are very experienced at driving on frozen lakes because there is not much difference between the two.
NE1 try the Nitto, looks like they last a lot longer and hook well on the street, but not as good on the strip.
http://www.discounttire.com/dtcs/re...5&ar=60&rd=15&cs=275&pc=40206&pager.offset=20
They don't hook up very well. I pulled it out of the garage and drove it around the block. It was a little cold with no windshield. 8)
Ain't that the truth. I'm running 28x12.5x15 ET/Street tires on the Demon. One Sunday evening in 2000, I was driving my Demon back to where I kept it stored. I was trying to get back before the storm hit. I was maybe 2 minutes away when the torrential rains hit. I was going up a big hill 2 blocks away, but it was just pouring out. The tires started spinning 1/2 way up the hill. Just like being on ice. I started sliding backwards with traffic coming up behind me. I was able to parallel park the Demon against a curb until the rains stopped. Scary as hell sliding backwards downhill in traffic. My butt gave it a pucker power of 8.5 :bootysha:
Wylde1.
