↑I wrote
Im old school and say "F" the cats!!!!!! but if you're using a computer and injectors, that will set the trim by reading the o2 on both side of the cat. Use the pre and post o2s as it will keep the cat tuned and will last A WHOLE LOT LONGER!
Magnummopar wrote
I missed something, the only way I know how to tune a cat is to take its guts out and string your guitar with them, otherwise, its just a metal can filled with ceramic honeycomb and precious metals, no way to tune it.
If there is not enough gas to "light", the cat, the cat will plug. If there is too much gas the ceramic Honeycomb will Melt......then plug.(and your carpet as well, without a heat shield of some sort.
