Anyone running 275/60/15's on a stock 8-3/4
'71_Demon
Member
Woodridge, IL
I am finally getting around to putting my new rims on.
They are: 15x7's with a 4-1/2 inch backspace. I really want so meats in the back, so I am looking to put 275/60/15 on but i dont want any rubbing. So has is anyone running this combo?
Thanks Kevin
325x50x15 are what's on the back of my Demon.
It does have the off set spring hangers, Not the spring relocation kit, but the 3/4" offset hangers.
Kevin,if you want rubber in the rear get your self a set of hossiers,32X16.5X15 like I have on the dart,now we are talking rubber,Mrmopartech
Mopower- I like the way your Demon sits. Thats what I am looking for. I would buck up for the offset shackles but I just dumped a bumch in the rearend including new straight shackles. I take it the tires would rub without the shackles in?What rim demensions (backspacing,width.etc)?
Mrmopartech- Geez now your talkin. I think that is a little out of reach I also have to buy studs and slick/tubes for another set of wheels. Did you fit those on a stock 8-3/4? What kind of backspacing?
Anyone else running these tires of a stock rear suspension?
Kevin
