Anyone running a cable throttle body on a 5.7?
I am running a 92mm Sniper TB om my motor with a Lokar Cable to the factory peddle. you might need to bend the arm on the peddle to get 100% it doesn't take much.
I have the BBK-1792 on my 6.1. No adapter plate needed and the cable hook up is on the correct side for my setup
Did you get your BBK to work with Terminator x ECU? Im running into issues with TPS/IAC sensors. Both sensors have one less wire....did you run into this?
What ECU did you run? I’m running a terminator x and bbk 1792 TB. Having trouble with IAC hook up. Harness is 4 pin and IAC is 2 pin. Did you have this issue?
Most standalone system harnesses are designed to work with GM type sensors for IAC, TPS, CLT, MAT, etc. I have no idea what the BBK sensors are compatible with. Maybe someone makes adapters for this, but I'm not aware. You may be better off using an LS style throttle body.
