Anyone running the air gap
69DARTS
69 Darts Rule
indiana
Any one running the air gap intake.
On there abody small block pics
How is hood clearance.
It's a bit tight but can easily be addressed with a drop base or thinner air cleaner. 65'
I had no clearance issue at all on my 73 Duster running the stock air cleaner.
Not an air gap, but I have a Edelbrock Victor 340 intake on mine, which is also a high rise intake. I am running a stock '69 340 air cleaner, hood clearance is close but it fits.
Probably 50% of us are running Air Gaps on at least 1 car. Using a drop base air cleaner allows for plenty of clearance .
Mancini offs one for the 68/69 340/383/440 style . I have one on my Dart with a Victor intake and 1" spacer.
73 Swinger, just a tiny little spot where the air cleaner hits the hood.
Definitely need a drop base, and stock ride height in the front.
I am running an air gap but so far haven't found a drop base that ALSO clears my electric choke on the Edelbrock AVS carb I have ? I REALLY want to run the stock air cleaner but it has to fit right. What drop base are you guys using?? I think the stock air cleaner just looks "right" it just doesn't clear the hood!!!
Mancini sells a drop base for 68/69 HP that clears .
I have one on a AVS-2 in my Barracuda
340, Air Gap and Edelbrock with unsilenced air cleaner. Fits but so close a 1/2” carb spacer may not clear.
I used to run an airgap then went to the Victor 340 and it made me forget the airgap!! It does everything the airgap did but with more top end.
I have a 69 Barracuda with a 340 and an Air Gap. Hood clearance was very tight, so I went with a drop base air cleaner and a 2" tall filter instead of the standard 3" one. I called K&N, and they said it would easily flow as much (or more) than a 3" paper filter.
