Anyone using stock ECM and harness?
I'd love the information please!!!
I'm struggling with how to make the 2005 truck harness work in my 1970 Duster. I've got the tipm and the 05 pcm and am using the 545rfe transmission. I was also wanting to use the instrument cluster from the same truck. The Dusters lights, turn signals and such will remain as is from the factory. I could definitely use some guidance in getting this thing to run. Please!
I have zero experience but have you checked with DIYHemi.com ?
Mike
I'm leaning towards breaking down and getting the Hot Wire harness and PCM.
In the end, I decided to order from Hotwire. Maybe I'll have this thing running by Christmas! That would be a very nice present to me!
You won't regret buying from Hotwire. Awesome customer service! Nice product and easy to use.
You will need to get a thermostat housing with a bung for a temp sender for your gauge. You cannot tap or put a T on the factory temp sender. Depending on what gauges you use. I used Speedhut gauges with GPS speedo I believe if you use factory speedo you will have to get a converter for it.
