D Drifterhp Member Joined Aug 8, 2019 Messages 16 Reaction score 1 Location Ca Jul 31, 2020 #1 Anyone using the slant 6 to sb conversion mounts in a 67-72 a body? If so on the pass side the isolator mount goes threw the steel bracket where do you have that nut on the lower hole or upper hole?
diymirage HP@idle > hondaHP@redline Joined Oct 12, 2012 Messages 33,919 Reaction score 42,264 Location michigan Jul 31, 2020 #2 if its the same as the driver side, the locator pin goes on the top (50/50 shot though, the constructions are not very clear)
