mopar65
The 318 that came in my 91 dakota sport had the LA motor mounts, but used the magnum mounts that ate cast in about the center of the block.
Also my 91 came with the A500 transmission
Why?I was hoping for a 518
Not sure I'd call them special but I have only seen 714 casting heads on 1991 model 318s. Some debate can be had on the differences between them an 302 casting heads However, in one flow test I've seen they offered a rather healthy benefit over the strikingly similar 302... (about 8 minutes into this video: ) ...food for thought and I'd like to see that test repeated.
PLEASE pay attention to the following:
Vertical video looks terrible. Rotate the phone 90 degrees and record it this way.
Every 318 I have ever been into has had flat top Pistons unlike any 360 I have ever been into which are all dished (at least in stock form) can't say I like how far in the hole they are at TDC some years, though.Few 318 that had true flat top pistons. RRR pointed this out years ago to me looking for some flat tops. Thought they would bump the ol 68's compression but I sold it shortly after.
I thought all c bodies were 5000# tanks.Why?
The A500 has a better 1st and 2nd gear ratio for faster acceleration. Less rotating mass. Unless the C body wagon is a 5000 lb tank, the A500 may be durable enough to last awhile if it isn't abused.
