Are 1966 Barracuda Steering Columns the Same as 1965?
If your '65 is also a floor shift, and is the same P/S or no P/S type it will fit. The coupler may look a little different, but, works the same. Oh, the floor plate is different IIRC. You'd have to disassemble the column and swap it out to do the conversion, or cut the plate to get it on.
Thanks cudamark, was going to put on ebay. I will just list it for a 66. I appreciate it.
