cudamark
In a 273, yes....in a 318, no.68 was the first year for the hydro cam.
Yes, I own one. At least, that's what it came with when I bought the car in 1980. 8/17/65 build date '66 Barracuda had the 315 casting heads on it. It could have been changed, but, being a Hawaii car, I doubt there was much in the way of parts to be swapping around back then. It's a 4bbl car and still had the B273 block with appropriate date codes and HP pistons.I though there was a number of 66' 273s that had the earlier bolt angle-ed heads from 65' on them. I could be wrong (and often am) but I thought I got that information here at some point..
Same here. Mine is a 2bbl version that came with the car. I have gotten a few responses from others that have the earlier heads on their 66 273s as well.Yes, I own one. At least, that's what it came with when I bought the car in 1980. 8/17/65 build date '66 Barracuda had the 315 casting heads on it. It could have been changed, but, being a Hawaii car, I doubt there was much in the way of parts to be swapping around back then. It's a 4bbl car and still had the B273 block with appropriate date codes and HP pistons.
Here's what I have found playing with these 273's for over 40 years now, and not counting exhaust manifolds, oil pans, motor mounts, and other bolt-on parts. The '64 only came in a 2bbl version, and had the 315 casting heads with matching intake. Forged crank, solid lifter cam with adjustable rockers. '65's were pretty much the same except that they added a 4bbl version that came with a higher compression piston and higher lift cam. '66 started (for the most part) the 920 casting head and matching intake....in both a 2bbl and 4bbl version. They also came in both a C.A.P. (Cleaner Air Package) and non C.A.P. '67 continued that same engine. In '68 and '69 there was only a 2bbl version, 675 casting heads (same as the 318 those years) hydraulic cam, and a cast crank with the larger convertor register (also same as the 318). The blocks also have a different casting number. The only thing I remember being different on the block is the number of motor mount bosses. The '64-7 have 3 bosses on each side, and the '68-9 have all 4 in most cases. There are a few oddballs though. I've seen a couple with 3 on one side and 4 on the other. Very weird. some of the early 318's did the same thing, but, when they had 3 bosses, it was a different 3 than the 273. This required a tab to be added (welded) to the motor mount bracket to get all 3 bracket bolts to be used. In your case, any of the those 273's or early 318's will bolt into your car by using your existing 273 bolt-on parts. The only exception here is if your B-body has a 727 transmission behind it. In that case, you would need an engine with the large convertor hole, or, you would need to swap in a crank with one. And yes, before anyone argues about it, they did make that option in a B-body. Very rare, but, taxi's, police, and special orders had them (not to mention and the poly 318 cars that year). Those vehicles used a 318 forged crank like what also came in an A100 van with a 273. If you want some cheap horsepower, I'd get that 318 engine as a spare to build. Put it in when you want, run it as hard as you want, and keep the original engine for when you want to start a restoration project on the car.It's been a while since I've posted here. I have been dealing with B and C bodies lately while my A-body sits on the back burner for now.
So in a thread on FBBO I talked about finding another 273 at a local junk yard that's going out of business. They said it came out of either a 66 or 67 Barracuda. I want it for a spare for my 65 Belvedere wagon 273. Are there any little differences in the motors that I should know about? Things like motor mount location, oil pan, oil pick up etc. I know my 65 Belvedere has it's little differences with later small blocks. I'm just wondering if there is anything I should be aware of or is it a direct bolt in? If it's a direct bolt in I may freshen it up and then rebuild the original in my B-body. Not looking for performance, just a stock 2 barrel motor.
Very possible. That's a early car.Yes, I own one. At least, that's what it came with when I bought the car in 1980. 8/17/65 build date '66 Barracuda had the 315 casting heads on it. It could have been changed, but, being a Hawaii car, I doubt there was much in the way of parts to be swapping around back then. It's a 4bbl car and still had the B273 block with appropriate date codes and HP pistons.
Yup, the earliest I've seen, and I've looked for an earlier one since I bought it in 1980.Very possible. That's a early car.
Someone on FBBO said there is a member here that makes a crank adapter bushing for this. Anyone know if this is true?Here's what I have found playing with these 273's for over 40 years now, and not counting exhaust manifolds, oil pans, motor mounts, and other bolt-on parts. The '64 only came in a 2bbl version, and had the 315 casting heads with matching intake. Forged crank, solid lifter cam with adjustable rockers. '65's were pretty much the same except that they added a 4bbl version that came with a higher compression piston and higher lift cam. '66 started (for the most part) the 920 casting head and matching intake....in both a 2bbl and 4bbl version. They also came in both a C.A.P. (Cleaner Air Package) and non C.A.P. '67 continued that same engine. In '68 and '69 there was only a 2bbl version, 675 casting heads (same as the 318 those years) hydraulic cam, and a cast crank with the larger convertor register (also same as the 318). The blocks also have a different casting number. The only thing I remember being different on the block is the number of motor mount bosses. The '64-7 have 3 bosses on each side, and the '68-9 have all 4 in most cases. There are a few oddballs though. I've seen a couple with 3 on one side and 4 on the other. Very weird. some of the early 318's did the same thing, but, when they had 3 bosses, it was a different 3 than the 273. This required a tab to be added (welded) to the motor mount bracket to get all 3 bracket bolts to be used. In your case, any of the those 273's or early 318's will bolt into your car by using your existing 273 bolt-on parts. The only exception here is if your B-body has a 727 transmission behind it. In that case, you would need an engine with the large convertor hole, or, you would need to swap in a crank with one. And yes, before anyone argues about it, they did make that option in a B-body. Very rare, but, taxi's, police, and special orders had them (not to mention and the poly 318 cars that year). Those vehicles used a 318 forged crank like what also came in an A100 van with a 273. If you want some cheap horsepower, I'd get that 318 engine as a spare to build. Put it in when you want, run it as hard as you want, and keep the original engine for when you want to start a restoration project on the car.
Are you referring to adapting a later large hole crank to accept a small button converter? If so, yes, those are available, but I can't remember who sells them. If you're referring to an early 273 crank that isn't machined for a manual trans pilot bushing, Brewer's has a BEARING assy to do that.Someone on FBBO said there is a member here that makes a crank adapter bushing for this. Anyone know if this is true?
A buddy of mine made me some wedding rings to address the later model register. Basicly if the later model crank is used with an early model torque converter with the smaller hub is used the rings take up the slack.Are you referring to adapting a later large hole crank to accept a small button converter? If so, yes, those are available, but I can't remember who sells them. If you're referring to an early 273 crank that isn't machined for a manual trans pilot bushing, Brewer's has a BEARING assy to do that.
AgreeNope. bolt it in.
