are SS springs enough
well not sure which ones I got but can you tell me which ones you used Vitamin? Im sure mine are the A body adjustables.
Josh,get your springs,perches and u-bolts all setup(together)Slide it all under the car,then hook up your hangers.Leave your u-bolts loose enough so you can adjust your pinion angle.Once you have your angle set,do some tacs to hold in place.Pull it all back out so you can get some good welds on your perches.Put all back in.LOL.Your gonna have to test the car to see how it feels(with pinion set at -6)if you have to,you can always shim it for more or less angle.Only launching the car will tell you how well it works or not.JMO:wink:
Can someone explain how unclamping the rear of the springs helps?
Here are a few launch pics of mine. I had one launch last time out that hung them about 6-8" but didn't get pics.
