Want to replace bolts on main. The 340 has the windage tray and the bolts for those have threads in them for the tray.My question is do ARP bolts have the same.
thanks
The ARP main stud kit part number is: 240-5501 and it has 4 longer studs to use for the windage tray. Like said above you have to line hone the mains if you switch to the studs.
