ARP Bolts, Proform 950 and Valve Covers
71-440-Duster
Northern Cal
ARP 140-5402 - main stud kit with 12 point nuts still in sealed box black oxide - $50
ARP stainless steel 12 point header bolts sealed - $20
ARP stainless steel 12 point oil pan bolts sealed - $30
Proform 950 cfm mechanical secondary race carb pulled for larger carb. Works excellent! - $500
Cal Custom Finned Valve Covers Big Block - Bead blasted and restored with black wrinkle finish - $100
Mike, x2 on that question. ProForm bowls are pretty intricate.
Can I see a better close up pic of the inside of one of those valve covers? Or just snap me a pic of the C.C. logo instead.
Sorry about that....I should have been more specific. It was a little late last night!
The carb was an 850 Holley that was upgraded using proforms base plate and body.
Here's a close up of the underside of the valve covers. It says Chrysler and the numbers looks like 644. Not sure, I'd have to verify this when I get home after work. I pulled these off my 71 Charger that the original owner had put on just after the purchase of the car, probably mid to late 1971 from his recollection.
Thanks 71-440. Sorry I wasn't more clear with my question; it was a close up of the inside of the Cal Customs valve covers I wanted to see, or a pic of the logo if it has one on the outside. They don't look like any Cal Customs I've ever seen.
