Brian Hafliger
Can you double-check the numbers? You may have misread a number.
Everything I've found including the ARP catalog shows:
144-3605 - 318-360 Magnum with factory heads or Edelbrock Magnum heads
145-3606 - 383-400-413-426-440 Wedge
It appears that the Indy/RHS heads, LA-X and MA-X, would take 144-3605 since they are based on the Magnum heads, just machined differently for both applications.
The pic that Summit has is not the "actual" part because it shows 3 different lengths and it should be 2.
Those bolts are not in the arp catalog yet, or online. You have to either call them or me or someone who know's what's going on.
They are shorter than the Magnum bolts, hence the new part #! I found that the arp kits that already existed let the bolts hang down far too much below the deck possibly allowing the bolt to bottom and that's not good!
ARP agreed with me after going over the column lengths of these RHS heads vs. others out there. Believe me, they would not have given a new part # out if they didn't need to.
Brian
