I put almost everything back on, knocked out the old wheel studs, and put in the oversized ones from Mancini to mount my new wheels and tires. I have 30x13.50's M/T on the rears, and man do they fill out. All that hard work mini tubbing it early on is paying off!!! I still have some room to spare in there too. I am rewiring the car now with a Ron Francis kit and ran into a hitch with the MSD ignition, can't get spark. So I need to troubleshoot some more stuff but I'm about 90% sure my distributor isn't compatable with the MSD box? I have juice to the box but not at the coil. I'm not sure what dist it is, looks stock too me, it worked fine when I parked it but that was when it was firing off of the stock ignition system, so who knows. It's not a points system and is electronic and the ground is good and I triple checked the wiring which is pretty basic. The other thing is I'm running super stock springs in the rear and I'd like to see the *** end lower than where it currently is, any suggestions on how to achieve this? I was thinking about some lowering blocks or removing some sections of the leafs.
