With a sheet of heat resistant gasket material & a small hammer, you can make yourself a set of perfect fitting gaskets. I've done it in the past & used the high temp RTV with the gaskets & they last a long time. Just a suggestion for you.[/
Demonracer, how would you do that?
I’m not a fabricator but in todays world getting Mopar parts is requiring extreme measures. A sheet of copper and an old header gasket as a template? How would you cut the D shaped holes? What would be a good gasket material. The old gaskets look to be some type of sandwiched copper.
