CudaFactHackJob
I used to get a headache trying to read one of AJ's posts...now I get a headache just THINKIN about reading one...
Ya I was told there wasn't going to be any math involved.I used to get a headache trying to read one of AJ's posts...now I get a headache just THINKIN about reading one...
Ask @AJ/FormS Wouldn't that be fun. Like driving a semi.Curious, does anyone make a a programmable control box that would operate a GV's unit so it would split each gear automatically? I like the idea of using a 727 but wouldn't want to be splitting gears manually all the time. Sometimes, hell, most times, I just want to cruise.
TREMEC TKXwhat trans can be used for overdrive automatic behind small block in dart ?
No problem on mine. I dropped the pinion down a couple of degrees.I have heard that the Gear Vendors gives screwed up driveshaft angles. True? If so, how hard to correct?
Almost but not quite ; the ratio is 1.13 verses 1.00, tho, pretty tight .Isn't 2nd over the same as third?
Pablum.2004s and 700s are JUNK. Lay out the guts from a 2004, 700 and 518 if you want a quickie course on strength. No contest; the GMs are stamped sheet metal whereas the Dodge is hardened machined steel.
If you want to drive a car across the country, then you got bigger problems than we have time to discuss here.
When did you ever drive across the country?
No, stupid statement.Ya, when? These overdrive threads only prove what a huge waste of time and money they are. Just because it can be done....
Mike is brutal. And funny.
