I'm installing an A500, but I think the answer for this would apply to all Torqueflites - which port in the side of the transmission pumps trans fluid to the cooler and which is the return line. I'm installing an aftermarket trans cooler and want the pressure line to go to the fitting on top and the return line to leave the bottom of the cooler.
Thanks!
Thanks!
