streetdak
So I got everything buttoned up on my 73, trying to get her ready to make a trip to the exhaust shop. So I took her for her newest maiden voyage after the cleanup/header project.
After once around the block I get her back in my driveway and see Oil spraying out from where the dipstick tube meets the block.
I know # 1 that yeah the disptick tube seems to have a hole where the seam is. I'm hoping all I have to do is replace the dipstick tube and voila i'm fixed.
However, with my new aluminum valve covers im only running a breather on one and a oil fill cap on the other. My question is am I building too much pressure in the crankcase meaning if I put in a new dipstick tube oil will still shoot up and out of it, or is my solution going to be installing a PVC system. The oil is spraying, not just leaking.
Any help I'd appreciate!
