Here is what I see on your pictures;
Your calipers are on the wrong sides.
The springs are e or b body just by looking at the rear spring eye they take the large diameter shackles. The hanger on the body won't let you instal the correct bushing without modifying it. He probably sold the springs is because he had the same problem
Your frame definitely needs to be addressed. you can see scaling covering the hole on the inside. Those rust chunks didn't get thrown in there.
Also whats with the screws holding that exhaust hanger? There is a spot on the rail for the hanger to mount it using a fender style J-clip.
One reminder is the front and rear hangers usually need to be upgraded to use SS or none A-body OEM springs . Pre 73 uses a different front hanger which changes spring eye height and bolt diameter. The rear needs to have a larger tube welded in for the larger bushing to match the spring eye.
One last thing , Where did you buy a housing with the spring perches welded on for your car? When ever you replace your housing or springs in your car they should be installed loose, pinion angle set. then tacked in place. I never bought a new housing with the perched welded on.
When installing SS springs many guys just put them on their existing perches. They will never work properly like that . I installed a set on a rear with an inboard kit and left the originals on. They ended up at different angles from one side to another. Then when I installed the Calvert mono leafs they had to be cut off due to them not setting on the springs evenly.
You need to find a local mech to help you on your car or you will be fighting issues and taking one step forward and two steps back the whole way. Just from what I have seen on this post you need someone to help you in person.
you can see the different angles on these pictures. We just cut them off again because we bought a different weight spring and are lowering the new car. Everytime you change a housing or spring your pinion angle should be set.
Sell the blocks to someone with a truck. LOL
