If there is a whirrring noise when you drive it it also needs a wheel bearing. You'll need the seal, some gear oil, some ultra black silicone or the cover gasket, and maybe the wheel bearing package (and a press or machine shop to replace it) if it needs the bearing. All parts will be for the 7 1/4 rear axle unless the car has been modified.
