loganscuda
This/These
:bloboes anyone have the part number for offset shackles and who to get them from. Can I use those instead of moving and welding on new spring perches.
You can pull the springs to the perches. Its only 1/2 inch per side.
If you ever replaced worn out spring eye bushings you would see the outward pull is actually correcting the way those bushings wear.
