[WANTED] B Body Drivers Side Crossmember Section
cosgig
MoBro Inc.
Pinckney, Michigan
howdy people, cosgig here. I’m working on changing the drivers side floorpan in a 70 Roadrunner, and the crossmember is a little weak where it meets the rocker. I’m looking for about a foot of the crossmember end to weld into place, maybe up to the torsion bar socket. If anybody is parting out a 68-70 B body and has this section, please message with what you have. I know AMD makes the entire crossmember, but it’s $400, a little steep for just needing the end. Any leads or input would be much appreciated. I put a wanted on FBBO as well, but you guys have always come through for folks here.
Hey Cos, are you butt welding it in, and putting a U channel inside as a doubler reinforcement ? I know that's what I would do, after sandblasting and treating the inside of the crossmember.
I would recommend having the shop doing it to sandblast inside the rail and coat it with a good epoxy primer to seal it up.
Yep, that’s what I’m doing, and it looks as if I’ll be doing it myself. And these convertible tops too. Unless a certain good buddy of mine wants to visit and help clean up a few dozen of these jobs!
