New in the box never used. B&M flexplate 10239. This is for a LA 360 and 904. With this you can run a neutral balance converter which is what most of them are especially high stall ones. this is still SFI approved. Otherwise on a externally balance 360 you have to use a converter with the weight on it. $100.00 Southwest Florida
