billytuffnuts
Have a couple questions about the b&m flexplate for a 360 magnum to 727 trans... I believe the part # is 10242
I know to use as stock magnum flexplate and a 727 converter, one of the bolt holes on the flexplate needs to be elongated to fit, does that need to be done with the b&m version too?
Also, the converter I have uses the larger 7/16 bolts, will I have to enlargen the b&m's holes to fit?
