chrisnben
MR Badfish
Mopar big block parts- All parts are priced without shipping, please include your zip code with PM response for ship quote. All parts are located and shipped from Sun Prairie, WI 53590.
[/URL][/IMG]
'74 440 block, standard bore- honed, newer cam bearings, standard deck height. Great block for a street engine. includes main caps & bolts, freshly polished cast crank, balancer, timing cover, water pump & housing, full set of factory LY rods & flat-top pistons as well. All ready to assemble. $400 (pick up here only)
Milodon B/RB 7qt low-profile deep oil pan with Milodon pickup tube SOLD
B/RB Mopar 1967 '906' heads, ready to run- recent valve job, new seals, surfaced. $200
B/RB Mopar Performance aluminum finned valve covers, polished. $80
Crane aluminum roller rockers 1.6 ratio with shafts and hardware. pending sale
Chuck Neuten- Holley HP 750 carb. Milled air horn, 4-corner idle, clear site plugs; flows 1000cfm. Super nice carb- I've had it for years. ready to run. pending sale
383/400 B motor Edelbrock RPM intake manifold Excellent cond. ready to run $195
440 Mopar Direct Connection tach-drive electronic distributor, adjustable mechanical advance. Great peice- no longer pruduced! Ready to run. pending sale
Package deal: heads, intake water pump, lines. pending sale
B/RB Edelbrock RPM aluminum heads; milled to 76cc chamber, full max-wedge port work, CompCams beehive springs, stainless 2.14/1.88 valves, 4 angle valve job, 10 degree locks & retainers, flow charts available (305 int @ .600 lift) Heads could use cleanup in chambers, lost a piston; only cosmetic- I can have the chambers run on CNC program- would bring the chamber volume to +/- 80cc. please inquire for info, deck height, flow #'s, etc.
Mopar Performance M-1 single plane intake port-matched to RPM heads
Mopar Performance aluminum water pump & housing w/ external ports for (-8AN) braided cooling to RPM heads above.
Package price. pending sale. (I have $3500 into this set-up)
CompCams B/RB Solid flat tappet cam & lifters (in order) great condition low miles. Specs: 267/273 duration @ .050; Valve lift- IN .660/ EX- .648; lobe separation 110; @ 108 centerline. $175
