Back in an A body!
6SLNGR
NY
After over 20 years I have finally found myself owning an a body again.
My first car ever was a 1972 swinger with a /6 auto. A few years later I had a 1972 valiant same set up. Stupidly parted with both over fixable things.
I just bought a 1975 dart custom with /6 727.
You will definitely see me here as I fix it up.
Ps
what color is it?
Welcome, that's a fine looking more-door! We need more pics of the rest of it. Is it as nice all over?
While you take more pics (hint-hint) take one of the fender tag. We can decode your color from that.
Welcome Aboard!
Lots of information in here...and a brain trust you'll find no other place.
Bunch of sources for options and colors. Does the car have a fender tag that you might decode?
General info
Good Luck
Looks like your color is KY4, Golden Fawn. I input your info as best as I can read it, but undoubtedly some codes are off - the tag is hard to read. Here is what we get, reading left to right, bottom row up. If you can give better code info for the hard-to-read ones, we can get a better readout.
LH41:
Dodge Dart,Demon
Unknown
4 Door Sedan
C5F: Unknown
Unknown
Newark, DE, USA
182523: Sequence number
E24: 225 cid 1 barrel 6 Cylinder 145hp
D34: Light Duty Automatic Transmission
KY4: Golden Fawn (Dodge) Exterior Color
L1YA: Trim - Low, Unknown, Unknown Color
KY4: Golden Fawn (Dodge) Int. Door Frames
804: Build Date: August 04
120987: Order number
V1Y: Full Vinyl Top, Gold
U: USA Specifications
C25: 69 only Left Head Restraint
C52: Bench Seat
J52: Inside Hood Release
L31: Hood/Fender Mounted Turn Signals
L73: Seatbelt Unfastened Lamp
V21: Performance Hood Treatment
M25: Wide sill moldings
H38: Unknown
N65: 7 Blade Torque Drive Fan
22: Unknown
