Back on the road!
PheelACCD
Member
Glendale, CA
Hey all,
I finally got my old '69 Dart running again and I'm super excited to get started on the renovations... with an "s" because June -that's her name*- is going to need a LOT of love.
She started as a green Dart Custom with a /6, and was later outfitted with a 318. There's a couple of go-fast parts and she runs okay but not great. All those parts and the engine swap were done by previous owners and I have no info about them.
Recently I got the transmission rebuilt, the Hurst Pro2 shifter repaired, some leaks fixed, the freeze plug changed and a new alternator was installed. Brakes and exhaust were done a couple years back and I replace the rear struts.
Next up is fixing the carburetor and putting some new wheels in (AR 767 are my choice so far). Wondering which size to go with, leaning toward 15x8 all around with the 114.3mm (4.5 inch) spacing. Will I need an adapter? The rubber will come from some Hankook Ventus with white lettering.
ALL suggestions and comments will be welcomed... I'm new at this! :cheers:
I'm very grateful this forum and community exist!
Cheers!
*if you guess why, we'll be friends forever :) .
Looks like you've been around for a long time, but Welcome anyway. --
You're right, I had joined the forum, but June was just sitting until I had more funds and I wasn't sure how I would contribute... I know... it's silly. Thank you for your welcoming message :)
Welcome! and just a note on the tires. On my dart I was running 15x8s w/4.5bs on the rear with 255 tires, but rubbed slightly so I went to a 15x7 and 4.5 and a 255 tire and it fits perfectly. Up front I have 15x6 w/3.5bs and a 215 tire, they fit good, but the car is so low they sometimes rub a bit.
Point being I dont know if 15x8s will fit all around if you want to fit any decent tire under there lol. I know 255s for me dont cut it for traction at all.
Thanks for the tips DartVadar! Much appreciated.
ScampMike and goldfish65... good guesses but.... sorry, not the right answer! :)
