backyard diy junkyard disc brakes front and pback
paul smart
belleville ontario canada
ok kids all you people with knowledge from knowledge land id like to see us come up with a disc brake kit front and back by just pieceing something together from other vehicles.
this kit will have to fit a abody car with drums all the way around so we need bearings that fit drum spindles and brackets for the calipers etc etc.
also it doesnt matter what these parts are from now is the time to show your stuff and see what people have used thru the years.
CAUTION.evrything used has to be safe no bail and twine stuff to stop the car the parts have to come from another car or truck and provide the year make and model of car you lifted the parts from.
some stuff-
front rotors,seals,bearings,calipers,brackets etc
rear rotors,seals,bearings,e-brake calipers,e-brake cables,brackets
for instance i have a 85 toyota pickup with beefed disc all the way around
the front are landcruiser vented rotors with 4 piston 99 forrunner aluminum calipers and the rear i have chev 1 inch rotors with the center hole opened up that slide over the axle with aftermarket caliper brakets that holds early 80s olds-caddy e-brake calipers and a usable e brake
You don't need a kit, or a parts listing, to do a disc brake swap on the front end.
It's been done already, a bazillion times, with junk yard A, B, E, body parts, and F, M, J, body parts.
