72dustyer
All go, no show
I filled up with some of the $3.25 a gal stuff and now the car won't run right. This is only the second tankful I ran thru it since rebuild. It'll idle OK, but after a once around the block it stumbles and dies. I checked fuel pressure and it's OK @ 7.5 psi, which is what my 750 dbl pumper wants. I also emptied the fuel filter with no signs of contamination. Could it be bad gas? or is it something else like the wrong size powervalve. Bad gas wouldn't let me idle at all correct?
