PanGasket
has cork sides
just bought a priming tool off Summit. Total after shipping and hooha... like 12$. Not bad.
hi, I assume you dropped the oil pump to install the new pickup tube??
when you bolt up the pump, some times the pump will hit the rear main cap bolt head and **** it. causes a gap between pump and cap flanges. the mopar race book talks about this problem. If this is the case, you had no pressure. mopar says , might have to rotate that bolt some to clear pump so it will mate up correctly. I have seen this happen before, one guy tightened his down and broke the pump base!!! there is not a lot of room there, just food for thought!!!
thats what i use pishta,works great.didn't want to wait for mail order....:violent1:You wanna talk about cheap? Hit a 18" piece of 3/8 allthread with a cut off wheel to make the end a hex shape...now THAT is cheap, and I bet you got something like that laying around the shop on a sunday night.....Your not screwed, your just low on oil pressure. Get it primed before you start it again and see what you got in pressure afterwords. A tossed lifter from a broken pushrod will cause the oil pressure to bleed out of the open lifter hole, little to nill oil pressure will register.
I agree you should ALWAYS use a priming rod to check for oil pressure before firing the engine. That way you'll know everything is allright before you ever start the engine and potentially damage things. Anymore I don't even trust new oil pumps after seeing some garbage in the relief valve of a brand new supposedly "tested" Mellings oil pump. I always completely disassemble them and clean them and check the clearances before they go in. Only costs a 19/32" relief valve plug and 1/2 hr. to make sure everythings right with the pump. 73Swinger318 I hope this turns out to be a minor learning lesson, nothing major.
holy crap that thing is destroyed. take the distributor out and if its not froze in the bushing it will slide out from the topFound the problem. Looks like the drive shaft is rounded off too. Whats the best way to get the shaft out?
Distributer is out. Cant get the shaft to lift out.
