Bill Crowell
So the alternator on my '62 Valiant stopped charging the battery. The alternator was producing charging voltage but the ammeter never showed a charge, only a discharge. I traced this to loose connections at the ammeter, which now reads correctly and the alternator is now charging the battery OK. However, when I tightened the ammeter connections, the oil pressure gauge and the temperature gauge started going off the high end of their scales. I'm thinking maybe the bad ammeter connections were masking a bad instrument voltage regulator, which is now supplying the full 12 volts to the instruments, but I'm not sure. Your thoughts?
