Howdy all. I have a longstanding charging system question that I vowed to get to the bottom of once and for all, and I need the help of the FABO electrical guru's to help me out!!! Heres the dilemma...
1966 Barracuda, 273, auto, stock wiring except for an upgrade to the Mopar Performance electronic ignition and later style voltage regulator and dual field alternator. Before I switched over the the dual field charging system I was running the original mechanical voltage regulator with the second field wire grounded to the case of the alternator and all was well with the charging system. Now that I've switched over to the newer style regulator I finished the second field wire to the ignition "RUN" side of the ballast resistor by splicing it into the blue wire coming off the regulator, as spelled out in an article in Mopar Muscle magazine. They chronicled the entire process and stated that when splicing in the second field wire and the newer style regulator plug to just make the splice for the second field wire to the blue wire at that location.
OK, now the problem... with both field wires hooked up, the guage reads slightly charging at idle, and during even slightly more than off idle will peg the meter. Here are my steps to diagnose so far...
Take off added field wire from alternator, original still hooked up= no charging
Take off original field wire, second still hooked up= still pegs the guage
Switch the field wires at the alternator= kills the car
Meter readings...
Original field wire hooked up or unhooked= no voltage
Second field wire unhooked= almost 14V at idle, climbs to high 14V then levels off at 2000rpm or so
Both field wires hooked up= second field wire voltage starts at near 14V and steadily climbs during exceleration to over 18V
Both wires unhooked and testing the field terminals on alternator= no voltage
I need to get this electrical system charging correctly but not overcharging, and I can't figure out why simply switching the field wires on the alternator kills the car and won't allow it to start. It seems like I have everything wired in correctly, and by the meter readings from the second field wire that the regulator is working, and the alternator is also working...so what gives???
I hope I spelled out all the necessary facts for at least some suggestions, and I'm hoping that someone in the FABO community will be able to solve this, and maybe explain the field situation, and maybe how the field thing actually works. I'm stumped!!! HELP!!!!
Thanks all for any input received, you all rock!!! Geof
Meter readings...
