I was thinking from back when I had the 273 that was built for strip use when I got the Barracuda.
My question is about a small diameter pulley that required me to remove the crank balancer bolt to remove it. It was 2 groove and diameter of a pop can. I took it off because of obvious charging and cooling issues on street and applied the bigger diameter that is factory. Does anyone know what I'm talking about or was it just a fluke pulley that fit the balancer / crank?
Eric
Eric
