Ball and cup replacement for a mild 273
xLURKxDOGx
"An angel fat, at satan's feast"
PHX
Just call Smith Brothers. You really should verify pushrod length before ordering. Also, make sure the shafts are grooved, especially if going on a hydraulic cam.
Cool. Is hydraulic not the best way to go? When i bought the engine it came with hydraulic lifters so i figured i would go the same route.
Jake
That is for sure , save yourself some time and machining costs
Adjustable rockers really aren't necessary with a hydraulic cam. The factory hydraulic rockers and pushrods are engineered for the proper preload. There is no performance gains by using the adjustables.
