Ball stud bracket ??
slickchick
pedal cars only
maryland
Which ball stud bracket {for the bellhousing}is used with the later O.D. bellhousing in an early A body {65 Vali}
thanks in advance
That is for the 10.5 bellhousing conversion on the early A.
If you look at the description it lists the bellhousings it works with, it will work with the 72 up bellhousing and therefore the OD bellhousing. Do you know the casting number of the bellhousing you want to use?
