Hi, i talked to a fellow Mopar guy, he has a 1971 dart 340. he is running his Mopar electronic ignition with out a ballast. is it safe to not use any ballast with his Mopar ignition system and if he neededs one what ballast should he use?
I would "get back" to a more street traditional setup. You can create a situation where the coil runs hot and fails, and you can have a situation where the ECU is switching too much current and fails
Additionally, I disagree with the idea of running a coil designed for no ballast. The reason is that these were designed originally so that during start, when battery voltage is lower, the ballast is bypassed to provide a hotter starting spark.
You are a smart guy, no question, BUT if I am using a coil not needing a ballast, then the coil will have the full voltage avalible at all times, even when cold. And of course an ignition system not needing reduced voltage, like I am using, needs to be used as well. No ballast works fine in my setup.I would "get back" to a more street traditional setup. You can create a situation where the coil runs hot and fails, and you can have a situation where the ECU is switching too much current and fails
Actually from my point of view the solution is to use an HEI module
The stock PN 2095501 is best; that is 0.5-0.6 ohms cold; I find them on eBay. Next best is the MSD 0.8 ohms cold that you can get a lot of places. 3rd best is the BWD RU19 at about 1 ohm cold, that is at many box stores. I would not bother with anything else except for an emergency.what 2 wire ballast size should he be using with his electronic ignition? 1 ohm? 1.4ohm?
If that were the case, then a regular resistor would be used, not a ballast type that changes resistance with temperature. 'Ballast' has a specific meaning and function in electronics; it is a basic form of current regulator. The 'resistance' (pardon the pun) to using actual electronics knowledge in this matter is perplexing ..... ??The "original" intent for ballast resistors was to cut the voltage to the points, thus making them last longer. The coil will also get hotter without one.
....... 'Ballast' has a specific meaning and function in electronics; it is a basic form of current regulator. ..... ??
Nice!In an attempt to keep a numbers car looking stock under the hood. I solder a 12 ga wire at the rear of the 2 post ballast to provide constant 12 volts. Then I use a pertonix Electronic ign system inside the stock distributor, also to keep stock looking appearance. There are two wires exiting the distributor, but I use a shrink wrap to hide the 2, and make it look more like 1. Here is a pic, although not a great one.
