Which way does the link bar point. Towards the cylinders are to the cam side. There is the oil pressure hole to feed the axel under pressure only on the link bar side of the lifter. If they are installed with the link bar towards the cam then the oiling holes wont be on the lifter oiling galley to feed the axel. There is interference with the bar to block if they are installed on the cylinder side , but thats where the oiling hole is. anybody ran into something like this.
