I knew a girl that did that once.....Hmmmmmmm
There is some on the hood down side. I will definitely keep an eye on them. Already checked them once after installing new rockers and shafts. Took a press to get the rocker off.
If you can see how an over tight shaft can cause a bind, you can see how a loose one would.I do not see how a loose shaft could cause the rocker to bind on the shaft. An overtightened shaft, yes, because it is no longer round, but oval shaped.
A loose shaft, if loose enough, would leak oil pressure & may starve the rockers.
The pic in post #22 tells the story....
A loose shaft can't be distorted by load from the lifters and springs, but can be distorted by over tightening of the hold downs?No, do not agree that a loose shaft would cause binding. Maybe if the shaft was 1/16" wall thickness, but it is muuuuch thicker than that.....
"Original"?15 years and 1000’s of runs and 60,000+ street miles. They are the original rockers. I will look at the new shafts, when I check them. The rocker has a full groove in the middle where that hole is. That is the cast iron pedestal side.
Turbo,
Using your logic: the side of the rocker closest to the spacers separating the rockers would bind because that area is between the shaft hold downs & is unsupported.
'A shaft moving around'......
Not for long. The bolts will back out & there would be quite a bit of valvetrain noise requiring the engine to be stopped to investigate.....
