LH23H2R
I apologise if this is a redundant thread ; an issue that's been addressed ad infinium :clock: ...
Band Adjustments : 904-LA with a Trans-Go improver kit
( TF-1 , iirc ) , ~30,000 since it was rebuilt ( steels , frictions , high-gear band , new stock stall-speed converter ;
pretty basic ) , and about ~8,000 since I drained its fluid via the pan ( 4qts ) and replaced the filtre .
Anyhow ... I figured with 30,000 on it , that a band adjustment was in order ; however , I cannot recall :
- where the adjusters are located
- what are good , performance-oriented tightening specs
While the Trans-Go definitely helped a lot , I believe that the builder set the bands at stock ( read : soft ) specs .
Granted , this 904 is behind a stock 318 , and followed by a 2.71 gear ; I just despise mediocre shifts , especially at uphill-on-ramps-to-uphill-travel-lanes acceleration speeds :angry7:.
Anyhow ... I'd appreciate some feedback on this deal ; some recommendations on tightening specs , and where the hell the adjusters are located :read2: .
Thanks !
Thanks !
